Hi
After idling about ~5min and accelerating there isnt like any power, not even enough to spin the tires at 1st gear. Then driving about 5kilometers on highway and accelerating again its much better, but still isnt good enough
Codes i got from carly
000016 - “Exhaust camshaft VANOS advance valve, Cyl #1-4”
000009 - “Knock sensor, Cyl #1-2”
FF - “Exhaust camshaft VANOS sealing, Cyl #5-8”
Secondary air system. Flow rate too low (bank2)
Radiator fan. Short to ground (visco fan is working, climate fan isnt)
This could be caused by vanos according to first three codes? Can vanos not working correctly but up knock sensor code? And after driving on highway the acceleration gets better?
Last year these parts were changed (5000km ago max)
07.22 fuel pressure regulator
6.22 radiator
08.21 fuel pump (Pierburg)
08.21 2x pre cat lambda (Bosch)
08.21 8x spark plugs NGK BKR6EQUP
08.21 Vcg seals + bolt seals
08.21 all vacuum hoses (OEM)
08.21 2x MAFs (Bosch)
08.21 2x CPS (exhaust)
08.21 knock sensor cyl 1-4 (Bosch)
07.21 8x ignition coils (Bremi)
06.21 fuel filter (Mann)
6.22 radiator
