1 - 11 of 11 Posts
1) I'm very interested
2) Do these require spacers up front to run the stock wheels?
3) How much for shipping to 02719?
Thanks!
From my understanding, these should be fine on the stock staggered setup. Tire width may make a difference and cause slight rub on the collar though but most 245 size tires should work fine.
When running a square setup on 275s a minimum of 12mm spacer is required to clear the collar. The 18x8 fronts sit 13mm further out as is.
I'll check on a quote tonight and get back to you. Thanks!
Sent from my Pixel 3 XL using Tapatalk
Interested too if the purchaser falls through.
So they were never installed on the car correct?
Correct, I opened the box recently to send pictures to another interested member and that is the extent of it.
1 - 11 of 11 Posts
