1 - 3 of 3 Posts
Hi, i have a problem with my door lock, the keyfob does not work but shows a blinking light when i push the buttons, and when i put the key in the keyhole and open it will only open and unlock the driver side door while if i push lock/unlock button in the center console it works with all my doors, any ideas?
Thanks in advance :)
I’ve read about this before. There’s many threads on this. Possibly your fuel door actuator blowing the fuse. Also (unclear if you tried this), you should be able to unlock all doors with the key. Turn it counterclockwise once to unlock the drivers door, and turn it a second time to unlock all doors. Keep holding it counterclockwise and all your windows and sunroof should open too.
https://www.m5board.com/threads/central-locking-system-anyone-ever-seen-this.107504/
1 - 3 of 3 Posts
