Welcome lurkers (join up!), newbies, and veterans.
How do I Search?
There are 3 ways:
1. Use Google and type in “site:m5board.com e39” and then your other keywords.
Example: Let me google that for you
2. Look for the “Search this Forum” link in the upper right of each forum’s main page.
3. Look for the “Search” link near the upper center of each page.
M5board
http://www.m5board.com/vbulletin/e3...24875-m5board-com-stickers-now-available.html
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/187751-private-messaging-pm-threshold.html
HOWTO: Upload pictures to M5Board.com
http://www.m5board.com/vbulletin/e3...ur-mobile-m-m5board-com-tapatalk-enabled.html
http://www.m5board.com/vbulletin/e3...talk-app-iphone-android-blackberry-nokia.html
General
http://www.m5board.com/vbulletin/e3.../197746-very-best-bmw-dealers-indy-shops.html
Buying a car out of state tips?
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/249905-service-bulletins.html
Book recommendations
Website recommendations
ALL BMW technical documentation ONLINE!
MP3 disc creation guide
Aftermaket Warranty Information Database
List of Abbreviation/Terms
General E39 M5
Download E39 M5 Owner's Manuals
Owners Manuals in English for the 2000, 2002 and 2003 models are attached at the bottom of this post.
M5 E39 Body Style S62 engine FACTS
http://www.m5board.com/vbulletin/e3...p-e39-m5-extensive-production-statistics.html
M5 Common Problems and Running Costs
M5board featured in TotalBMW Buyer's Guide
Places to look for rust when buying an E39 M5
Videos: Learning to Launch and Shift the M5
Greg's M5 driving school
Recall Campaign 01V-206: Engine Auxiliary/Cooling Fan
Parts diagrams
Part groups BMW 5' E39, M5 (S62)
RealOEM.com * Diagram Selection
http://www.penskeparts.com/DiagramsMain.aspx?vid=47592&rnd=03192010
Audio
http://www.m5board.com/vbulletin/e3...714-e39-m5-m-audio-speaker-configuration.html
The Unofficial BMW M5 Messageboard (m5board.com) - Adding Amps to DSP WITHOUT Cleansweeps
http://www.m5board.com/vbulletin/e3...erience-upgradingthe-e39-m5-sound-system.html
http://www.m5board.com/vbulletin/e3...control-dynaudio-knukonceptz-advice-doug.html
http://www.m5board.com/vbulletin/e3...stereo-build-complete-aftermarket-system.html
http://www.m5board.com/vbulletin/e3...78306-aftermarket-stereo-subwoofers-pics.html
http://www.m5board.com/vbulletin/e3...t-i-call-m-audio-audio-upgrade-info-long.html
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/103536-m-audio-subwoofer-question.html
http://www.m5board.com/vbulletin/e3...7-how-much-power-can-m-audio-subs-handle.html
Battery
Battery Replacement Options: BMW, OE, etc..
http://www.m5board.com/vbulletin/e3...45-got-battery-drain-problems-check-here.html
Brakes
http://www.m5board.com/vbulletin/e3...g-ebc-red-brake-pads-any-gotchas-install.html
excellent brake article
Why aren't the OEM rotors cross-drilled?
Which Big Brake Kit (BBK)?
E39 M5 Brake Duct Modification
Code Reader
Peake Research tool for reading ODB2 & BMW fault codes
Which model Peake reader to get
Knowledge base on Peake codes for E39 M5
Drivetrain
Speeds, gears, torque, acceleration, rear-ends, etc.
Differential Leak
Jammed Transmission Selector Fix
Clean up shifter slop
Engine Oil
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/142633-what-bmw-has-say-subject-oil.html
http://www.m5board.com/vbulletin/e3...n/154780-intersting-read-oil-consumption.html
http://www.m5board.com/vbulletin/e3...177-oil-thread-actual-data-194-uoas-s62s.html
Oil FAQ
Engine
TPS & CPS sensors: camshaft position, crankshaft position, throttle position
http://www.m5board.com/vbulletin/e3...pping-sound-thats-much-ado-about-nothing.html (ticking, not rod bearings)
Banks Cylinders numbering
http://www.m5board.com/vbulletin/e3...d-rod-bearing-issues-please-post-details.html
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/152019-how-much-space-opposite-hood.html
How to test the MAFs yourself and How MAFs work
Cleaning MAFS
MAF sensor removal tool?
Carbon Buildup FAQ (summary) Peake AA code
Carbon Buildup FAQ (long)
Software fix for Carbon Build-Up issue
PICS: Carbon Cleaning- secondary air passages
Oil Filter Housing Mount
How VANOS work
Vanos Issues
VANOS Solenoid Replacement DIY
VANOS Warranty in California
Long and technical: thoughts on cold air intakes and temp sensor relocation
Steve Dinan's White Paper on the Dinan S2-M5 and Dyno Testing
Zionsville Super Duty Radiator Installation
Rod Bearing Replacement- In Car- Pictures and costs
Timing Chain Replacement, VANOS replacement and setting timing
http://www.m5board.com/vbulletin/e3...n/196276-rod-bearings-thread-compilation.html
http://www.m5board.com/vbulletin/e3...-up-close-personal-vanos-board-solenoids.html
Exhaust
http://www.m5board.com/vbulletin/e3...straight-pipe-muffler-delete-fact-thread.html
Info: When installing Supersprint Headers
Muffler Delete- ALL YOU NEED TO KNOW
Fuel
http://www.m5board.com/vbulletin/e3...y-fuel-pump-10-minutes-piece-copper-wire.html
http://www.m5board.com/vbulletin/e3...el-gauge-showed-1-3-tank-car-ran-out-gas.html
http://www.m5board.com/vbulletin/e3...r-fuel-filter-lately-filter-cut-open-pic.html
Another Fuel Tank Breather DIY (Peake E8 code)
Instrumentation
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/89257-home-link-genie-intellicode.html
Secret menu
www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/316282-m5-obc-secret-menu.html
Tech: How to reset your service indicator
NAV FAQ
NAV Hardware and Software Version
NAV Status Screen providing gyro data
4:3 to 16:9 navigation upgrade
Changing the viewing angle of the 16/9 navi screen
Oil Pressure Gauge Install
Missing Pixels on dashboard display
Repair guide for missing pixels in odometer display
Alternate Repair guide for missing pixels in odometer display - Ribbon Cable Replacement
Vent Fan Failure--Final Stage Unit replacement?
Troubleshooting non-working central locking system (key is not dead)
Troubleshooting remote trunk (boot) release
Rear Deck Rattle - DIY Fix
DIY guide for Bluetooth retrofit kit
Stealth One Software
Stealth One Manual
Suspension
www.m5board.com/vbulletin/e39-m5-e5...ilover-spring-shock-setups-compiled-here.html
http://www.m5board.com/vbulletin/e3...what-you-need-know-about-your-suspension.html
Suspension alignment specifications
Rear Swaybar Brackets
Fixed steering wheel vibration!
X5 Thrust arm bushings
Installing X5 bushings
Possible front control arm bushing failure?
Installing Ground Control suspension
http://www.m5board.com/vbulletin/e3...72-rear-suspension-overhaul-observations.html
http://www.m5board.com/vbulletin/e3...le-vids-steering-linkage-play-balljoints.html
Bodywork & Lights
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/208587-fasteners-undertrays.html
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/150669-wipers.html
http://www.m5board.com/vbulletin/e3...ht-into-bmws-failed-auto-dimming-mirrors.html
Angel Eyes - Stock vs PIAA vs ICE [PICS]
Installing Celis Tail Lights
Step-by-step paint scratch removal guide
Failing Electrochromic Mirror- Warranty Info
Adventures with Headlight Adjusters
Passenger side mirror replacement
00 --> 01 Front Headlight Conversion Instructions
Steering wheel / airbag upgrade
Wheels & Tires
Original Manufacturer of Chrome Shadow paint
http://www.m5board.com/vbulletin/e3...190909-3mm-spacers-rear-wheels-front-bbk.html
Special Project Cars
http://www.m5board.com/vbulletin/e3...eds-official-e39-m5-touring-build-thread.html
http://www.m5board.com/vbulletin/e3...-successful-s62-engine-rebuild-thank-you.html
http://www.m5board.com/vbulletin/e3...168649-cross-breed-2jz-m5-video-pictures.html
http://www.m5board.com/vbulletin/e3...-how-random-collection-parts-becomes-car.html
http://www.m5board.com/vbulletin/e3...200lb-supercharged-widebody-build-thread.html
http://www.m5board.com/vbulletin/e3...53039-life-my-e39-m5-show-car-my-journey.html
http://www.m5board.com/vbulletin/e3...-official-my-s62-z3-m-coupe-build-thread.html
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/163298-e39-ls1-swap-completed.html
M5 UTE conversion
My thoughts on living with a Area 51 Supercharged M5
On acquiring “El Diablo”, Black M5/Discovery Automotive über-beast!
Buildstory of DINAN supercharged 540i Touring
540i 4.9 Kompressor buildstory
Nowack N-500
S3 #17 Is Back From Dinan
First Impressions with my Dinan S3 #18. Test Drive today......
Dinan S3 project has started......
Report on Delivery of Dinan S3 #22 (pics) [Very comprehensive write-up]
Dinan S3 #23 is back
Build of NYC S3 #24 (Pictures)
NOS on e39 M5?
How do I Search?
There are 3 ways:
M5board
General
General E39 M5
Parts diagrams
Audio
Battery
Brakes
Code Reader
Drivetrain
Differential Leak
Engine Oil
Oil FAQ
Engine
Cleaning MAFS
How VANOS work
Vanos Issues
Exhaust
Fuel
Instrumentation
Secret menu
NAV FAQ
Stealth One Manual
Suspension
Bodywork & Lights
Wheels & Tires
M5 UTE conversion
Nowack N-500
NOS on e39 M5?
