1 - 17 of 17 Posts
could anyone let me know where to get a ball to go on to my towbar i have a bmw towbar fitted under the bumper behind the cover
Are you sure its not in the boot area anywhere? mine was in the right hand cubby hidden in a black poly cover, a friends was inhis spare wheel!
Tony,
let me see what I can do, I think a friend may have one I will check and post soon.
There are two type of BMW Towbars Westfalia and Oris. I'm not sure if the detachable portion is interchangeable. It would be worthwhile checking which you have.
Tony, nice looking car, noticed it on ebay a (short) while back. As you live in Prestwick, have you been to RMS engineering before, I was speaking to them about a replacement cat section, as my car was registered on 1st of Aug 92, theres a good chance that an MOT tester wont do a cat test if there's no cat fitted, therefore I was thinking of buying a non cat - cat section (if you catch my drift) from RMS, interested if you have any info on them.
cheers,
Phil.
tonym5 said:
hi phil
ilive in prestwick and its my m5 thats for sale
tony
hi phil
ihave used rms a few times i had an m3 e30 full system fitted ,i had a set of high level exhausts fitted to my bike, also they made a heatshield for my last car ,they done a good job on them all, also my cat has been removed but i kept the old one incase i need to fit it for the mot
tony
I have the westfalia bar. I can photograph it later today, and post here.
Rob Levinson's is an Oris bar, so you may be able to identify it by comparing to this photo - it's a completely different-looking bar to mine.
tonym5 said:
my towbar has a hole and it has a small red cover that fits inside
That's a Westfalia one the same as mine. The BMW price for a replacement hitch (Just the detachable bit) is around a ridiculous £250, and you'll also need a key for it. Perhaps one could be purchased from Westfalia? Still going to be expensive. Is the hitch definitely not in the boot trim? Mine's got a little clamp behind the trim on the RHS of the boot.
The little red piece is just a dust/dirt cover.
1 - 17 of 17 Posts
