Not sure if this is the correct section but I understand the auxiliary drive belts on my E34 B10 BiTurbo are standard 535i items therefore -
I've encountered a problem when changing my alternator/steering pump/air con drive belts on my Bi Turbo. I ordered replacements from ECP with the alternator one being 1055mm but a "cogged" item, making it too long - well, tensioned correctly would mean the adjustment on the alternator bracket would be at its limit. The belt I took off is slightly cogged but more like the old "V" type which is smooth on the driven surface with only slight "cogging" on it. The power steering one was slack and is a fully cogged type as is the air con one.
Do I need to get correct V type from my BMW Alpina dealer or a shorter cogged one (say 1000mm) from my local motor factors. Maybe I'm even trying to fit the wrong thing altogether.
Thanks for reading. It took me two hours to get the belts off, about an hour & a half to get the air con one off on its own due to restricted access in the BT engine bay
Any help gratefully received
