1 - 4 of 4 Posts
Hey guys, I'm having issues with my DSP amp which is making it impossible to access my CKM settings. I've tried recoding, replacing, and retrofitting my DSP but Progman/DIS can't seem to do it. Its also producing an I-Bus collision error, aside from that the AMP works great its just really frustrating that I literally cannot make any setting changes to my car/key memory.
do you have NCSExpert? you can read out the CI(coding index) and then use the correct one to code the DSP.
Yup, but I don't think my version can be switched to english...there isn't any option in the configuration sub menu. Also, when I try to load a profile I only get 2 options ZCS or Advanced; I'm not very familiar with it at the moment.
I know you've probably done this, but make sure the radio is on and the amp active when trying to set the CKM.
Same issue persists wether its on or off.
1 - 4 of 4 Posts
