Driver side angel eyes dimmer then passenger side
1348 6
Is it a user replaceable set of bulbs that would be causing it? Is it a type of bulb I can get an an auto parts store or something wacky I have to get from BMW parts?
And a few random pics that a friend took last night:
1 - 7 of 7 Posts
Have the same problem!
Any reply? :confused2
A couple things to try first; (1) switch the left bulb to the right and vice versa and (2) detach the plugs and reattach again to ensure a good connection. Doing (1) is probably good enough. Maybe you could switch the wires too. I've had this problem a couple times on two different 5 series and this trick worked both times. Finally, it's very possible that one bulb is not as good as the other. Just buy a new pair so that they match.
Ok,, so it's easy to swap the bulbs and change them, now the important question: Is it a dealer only part, or can I find it at auto parts stores?
If it's dealer only, is it something common most dealers carry in stock?
1 - 7 of 7 Posts
