1 - 20 of 29 Posts
It seems the SMG always defaults to D1 on start up. Unless I'm doing it wrong, D1 changes too early for my taste and makes the car gutless. Can I make it default to say D4 on startup? That would be more useful. I know I can use the M button for this but a decent default setting would be nice too.
Speaking of startup, can I get rid of the disclaimer screen on I-drive? That is a **** nuisance!
5 days and 1000km since picking the car up, I'm loving it overall. But I'm still not sure if all the optional settings are a boon or a curse.
AbruzziBoy said:
I looked in my downloaded M5 manual and found nothing about how to change the defaults. I'm sure there is a way to have the set up you desire upon start up.
Sorry no help on the drive logic.Where were you able to download M 5 owners manual . Thanks Crg
I found this a bit annoying as well.
All I do now is either tap the lever an extra bit to the right to select S when moving from neutral after starting, or change down on either control and that resumes the last S mode used. Change down as D1 starts in second gear.
Is this correct? Maybe I haven't been paying attention, but I assumed SMG III was similar to SMG II which always started the car in the program you were last using (unless of course you were in S6, in which case it would start in S5). I'm suprised that this is the case. Can someone confirm?
What happens if you engage S mode right after start? Does it necessarily engage S1 or the last S mode used?
Nipper said:
If you put the ignition key into position 2 then change the gears to D4 it memorises the selection. Turn off the ignition then turn back on and it ill show D4 again.
Please describe how this works. When I read it I immediately went down to the garage to try it but was unsuccessfull. It alway defaults to D1 with me. However switching to S it remembers the last setting used.
BTW Sydl, it is possible to program D modes unde the M-button.
Discussion Starter · #14 ·
Zenith said:
it's posted on this board somewhere IIRC. Do a search for it.
If that fails, you can contact me and I'll send it directly.
I've tried searching to no avail. If you believe the OM, it isn't possible to change the default setting for D. :grrrrr:
Nope - didn't work for me. Here's what I did:
1. Engine off, insert key
2. Turn key to postition 2 (the notch before starting the engine)
3. Press mode to D3
4. Turn key to position 0
5. Remove key
then
6. Insert key
7. Move gear stick to N, start engine
8. move gear stick to D - it's in D1
Nipper - can you post the instructions so we can follow?
3. Press mode to D3
5. Remove key
then
6. Insert key
Anyone get this to work?
EDC and DSC modes are saves but Power and Transmission always referts back to default on startup. I guess they did this so the electronics go easy on the engine when it's cold.
Which is a stupid reason because the first thing owners do is set it to D4 after starting the car. If that was the real reason then they would lock out D2-D5 until the engine was warm.
I thought of that aswell but would you really accept such a thing? Some of the electronics in the car are intrusive as it is would you really accept not being able to select higher shift programs just because BMW sais you can't.
I was just making a comment that if a tech/bmw told me that you can't save the D program across engine off and on is because they don't want the car to start in anything but D1 when it is cold is a BS answer. You can flick it to S5 straight away.
The fact that it doesn't save D settings is just crap.
1 - 20 of 29 Posts
