1 - 4 of 4 Posts
Hi guys!
Earlier I experienced something new with my little bimmer...
I did lock the door with the key instead of the lock-button. Also, returning to the car; I unlocked it with the key.
Then, when I started driving the car, it suddently autmatically locked all doors the "american way" (seen the same fuction in lot's of am cars).
When I locked the car with the button again, and then reopened it; this function was gone.
I would like to have this fuction, even using the button. Is there anyway I can activate this???
/AFX
Check this out:
Go to your dealer, them them you want your car and key memory programmed. Tell them you want to be in the garage with a tech to go through all the options and set them exactly as you like for each of your keys. Should cost you 1 hour labor.
http://www.x5world.com/articles.php?action=viewarticle&artid=85
I had a similar experience, I once un-locked the drivers door with the key instead of the remote. After that every time I un-locked the doors with the remote the steering wheel would automatically extend out all the way. Now I drive with the wheel in the fully opposite direction. So needless to say everytime I got into my car I had to re-adjust the steering wheel position. One of life's little annoyances.
So off to the dealer I go, and they had to re-program both my key-remotes. 1 hour worth of labor later, my problem was solved.
1 - 4 of 4 Posts
