1 - 15 of 15 Posts
I'm getting used to the SMG now and I really prefer it over the manual (no more "annoying in traffic" clutch pedal).
Most of the time I like shifting with the paddles but if I'm doing more than one thing e.g. going round a corner then I tend to shift with the lever. I'd say the ratio of use is about 70:30 in favour of the paddles.
Just curious as to what others are doing. I guess it depends on what type of roads you drive on most. What's your experience - paddles vs. lever shifting?
Probably 60:40 to paddles
90:10 lever.
It feels as if I can shift smoother with the lever.
When using the paddles it is also more of a "click" when shifting up or down
Paddles 100% of the time, I have not used the stick at all in the M5. When I had SMG on my M3 I used the stick about 50% of the time. In between I had a 911 C4S and when I picked up the E60 just started using the paddles or when in traffic use the auto mode which if perfectly okay for such occasions.
glad to hear that none of you miss the clutch. that is my biggest fear about my Third M5 due in october. i never minded the clutch in traffic ever and used the gears to contol torque/speed in my driving. are you able to have this same feeling in the smg version?
max
Active driving on twisty roads and high speed driving - always paddles.
Normal driving in town and lazy mixed driving - lever.
Cruising along with the family or talking in cellphone - auto mode.
When I first got the M5 I didn´t think I was going to use the lever at all, but have changed my mind. The lever actually gives a very nice shift feeling
Exactly the same here... Which gives the 60:40 affect to paddles, love the speed :D
90:10 in favour of the paddles. Definitely prefer them to the stick as I can hold on to the steering wheel whilst going hell for leather round the twisiting roads between Manchester and Sheffield!!! Fantastic!!!
A mix of lever/paddle/auto.
Lever is handy for upchanges when smoking (yeh yeh I know, filthy habit). Auto is handy for the kickdown so on single carriageway I will often slip in into Auto, kickdown to overtake, change up using the paddles and then slip into Auto for the next victim.:M5launch:
If your racing someone on the autobahn, it´s very convenient to put the SMG in D5. It shifts at max revs and you can focus 100% on the road and your contender :D
60:40 lever. It's nice to lean on your right arm [LHD] and shift with the lever. Also for some faster driving I tend to transfer to the paddles.
BTW I don't see how someone can use the paddles all the time. Because if you are in a tight turn it's not easy to find the right [lefthiha] paddle.
2009 M6 Coupe 24000 miles Saphire Black
Lever is handy for upchanges when smoking (yeh yeh I know, filthy habit). :
Its not the fact that you smoke that scares me--- its your life, ..... but that you actually smoke inside the M5 is scary. :hihihi: .... Imagine the smell after a while... :sad2:
A guy smart enough to choose an M5, should be smart enough to not smoke inside it, right hiha
I once considered to buy a car, everything was OK with the car, real beuty.... and then I jumped inside..... it was like jumping inside an ashtray.... I almost puked.....
NB! I did NOT buy that car....
To clarify my earlier post when in S mode I use paddles 100%, but I do use D mode when not pushing the car or in heavy traffic or manovering the car.
1 - 15 of 15 Posts
