1 - 10 of 10 Posts
I know I need caps and rotors, and I normally would think why not replace the wires...
but wires for $365?? Are you kidding me?? that's $60 per wire....
Pls shed some lights.
Thanks,
Super Moderator
i'd say probably no. You can test them with an ohm meter, not sure what the specs should be but probably posted here somewhere.
When i did my 'tune up', i kept the wires as is for now.
I changed the cap and rotor arm which was a huge improvement but after a week or so I started to get misfires again so I changed the leads as well. Once the leads were changed the difference was dramatic - much smoother low down and more power at the top end.
My car had done 130k miles and was on its original lead set. I know its alot of money but you will probably never need to change them again.
I had a rough idle and it misfired a little on top. When I changed the wires, the car ran excellent. So if you dont experience these problems maybe you dont need to. I changed the cap and rotor first then when I noticed that the misfire was still there I went for the wires.
Super Moderator
hmm, maybe i should change my wires!
Ok guys don't laugh at me now! :)
mottati,
You can check them at nite: take the wire cover of start your engine let it run a bit make it pitchblack in your garage and watch the wire very closely for lightnings :eek: for about 5-10 minutes
Hope that help,
Kris,
You can check them at nite: take the wire cover of start your engine let it run a bit make it pitchblack in your garage and watch the wire very closely for lightnings :eek: for about 5-10 minutes Hope that help said:
Dont forget to vent the exhaust gases if you do this or you will be very dead indeed. Just a reminder :)
Lets be safe out there...
I know this is hard but just change every thing once and for all. You will notice the great change in preformance and smoothness i think its worth it, maybe look around for a cheaper price but I highly recomend you do it.
Super Moderator
mottati,
Hope that help,
Kris,
That beats standing in a puddle of water and touching them with your tongue any day!
Thanks,
MSRP on the set from BMW is $653, so $365 isn't so bad. I see Pelican Parts has 'em for $355.50. And if you want an OE set mileoneparts.com has 'em for $522.40.
Wires don't last forever. And after 18 years and 110k miles I'm sure yours aren't as good as they should be.
1 - 10 of 10 Posts
