61 - 80 of 91 Posts
Bosch sensor 13477 installed on code 134 bank 1 sensor 1 or in English, passenger side front pre cat took care of the SES light. Thanks for all who wrote on the problem. I am now ordering as second sensor for the right side per advice.
Sensors
Hey Ty, I should have added another post. I changed my sensor, (bought a new NKG from the local parts store) and paid $120, way less than from the BMW dealer. And after two happy tanks of fuel the left hand precat piled up, drivers side. This time I bought a new one off of Amazon for $65 or so, a genuine Bosch, changed it out and am once again happy. I think the thing to do is change both when changing them. The toughest part is getting underneath the car, I am spoiled as I have a 4 post lift. Best of luck.
Kevin
What a great thread, thanks OP. I had same question as Northern, bank 1 sensor 1 on my OBD-II readers, so no question that means pre-cat, correct?
Will change them both out. Taking advantage of the price savings laid out in this thread.
Hey Edgy-39, the code that showed bank one cylinder 1 is on the passengers side or left, and sensor one I found on another thread being pre cat. Did just the one change and cleared the codes and it was good for a few days. I think you will win if you do both.
Happy Driving:wroom:
Thanks Blue. What tools did you use, you have any trouble swapping out the sensors? I have access to a lift.
I used a crow foot socket on a 3/8" drive ratchet. Make sure you use anti seize on the threads on the new one. You could buy the correct cut away socket on Amazon, but not needed I would say.
I wasn't sure if anyone mentioned this (was too lazy to read through 7 pages): if your crow's foot is 90 degrees (on the x-axis) to the torque wrench, you won't need to compensate.
I replaced both my pre-cat 02 sensors with premium/genuine OEM Bosch units & she now pulls even better then before. Entire job took less that 50 minutes & BimmerZone has the best price I have ever seen...
Sheesh. For $46/ea it's worth a return trip to NAPA to get my $74/ea back that I just paid over the weekend (haven't installed them yet). Thanks for the link.
Thanks to this thread I changed my pre cat O2s today before the dyno run.
The directions and pictures made it easier.
Love this board
Well, I decided it wasn't worth the return trip after all. I had some spare time this evening after putting the kid to sleep, so I swapped them out. They don't look too beat up. The parts are labeled with the same stamping as the new ones, but no idea if they are original or not.
I used my O2 sensor tool that I've had for a while, and it worked perfectly. I hit both sensors with some PB-50 lubricant about 10 minutes before removing them. I had no problems breaking them loose at all.
thanks for the instructions all,
easy intall, did the pre-cat O2 sensors only,
much smoother after cold start and up to 2000rpm and free revving past 6,500rpm too,
beast is back (again)
Any tips on getting the 10 year old sensors off the car, when your only using ramps? I tried penetrating fluid, but I can only get a 12 in wrench under there with the O2 removal adapter, and it will not budge.
61 - 80 of 91 Posts
