Thanks guys but I thought MKII doesn't need any tools to make TV-in motion work. I think it applies only for US then.
Allar
I have a '99 M5 and have disabled the TV motion check with the button presses noted above.
The real reason for the response is that there is a huge mis-conception about the whole "button combination" vs. "TV-on_Nav cable" that I see propagated regularly on various forums.
Although it is generally correct that the button press will only work on early 2000 or before models, it is NOT the Nav unit that decides, it's the TV module. My button press thing works perfectly well and I'm using a MKIV Nav setup with latest software / perspective view etc. For what it's worth, my car never had a MKI system, I started out with a MKII.
One of the reasons that I won't upgrade the display from 4:3 to 16:9 is that my TV tuner won't operate on the larger screen (99 model year) and the kids watch cartoons every morning on the way to school. In other words, not only do I have to buy the screen, I have to upgrade the TV (Video) module (which are hard to find and just as expensive as the screen) AND then buy a motion disabling cable
Here's an idea for those that have post-2000 cars with a 4:3 screen that they don't intend to upgrade. Find another owner with the same set up (all E39's come with potentially the same set up depending on options) but with a model year of early 2000 or less and just swap the TV (Video) modules. It's a 2 second swap job and your need for a cable will no longer exist.
:goldcup:
