drallen said:
I would go with stever's set up but get the 7" springs for the front instead of the 6.5" like stever...........
Mark
If you ask for 7" 550lb springs, the front of the car will likely sit too high. I am only making this statement after reading about Stever's adjustability range for the 6.5" version.
The 430lb springs with 7" free length compress a lot further compared to 550's, under chassis loading.
Based upon your comments, Mark, it almost sounds like a 430lb spring of 7.5" length is a good choice for folks interested in running a 13.75" or higher ride height.
Could you possibly tell me your rear spring part number, so I can determine free length? I would like to guesstimate what rear spring might be optimal for the 430 front.
The stiffer the spring, the shorter it's free length must be to maintain proper ride height.
