1 - 4 of 4 Posts
Which stage seemed to make the most difference? What rear shock adjustment you guys have and how does the car feel with that? Do you find that once you get hard on the brakes once you start getting shaking in the steering?
Don't know about any shaking in the steering on braking. Have not noticed any. Have the Stage 2 suspension. Shocks are set on the softest setting. I will stiffen things up when I get to the track. Prefer the softer ride for everyday driving. Actually the ride seems even better with the new shocks. Much more controlled feeling.
Mark
This is what I thought at first and had the dealer check for that and change. They said the rotors had grooves which is normal. Even after driving normally with the new rotors/pads, after a good high speed stop, the steering shaking with light application of the brake is back. Has anyone tried bending the dust shields for more cooling??
QUOTE]Originally posted by 4DRROCKT:
HK,
If you notice shaking in the steering while under braking, the chances are, your rotors might be warped....
[/QUOTE]
1 - 4 of 4 Posts
