1 - 2 of 2 Posts
Good Day All:
Does anyone know what size (188mm or 210mm) limited-slip differential a 1995 850 uses? Thanks in advance.
Feff
210mm is the only option, this diff has 8 bolts on the diff output bearing.
A 1995 will most likely require swapping the diff input yoke from your diff and that is better done by a professional diff shop or someone that knows how to measure/set the pinon bearing preload while re-torquing the pinon nut.
1 - 2 of 2 Posts
