1 - 10 of 10 Posts
So last year, after 6-7 months of owning the car, I finally discovered the secret menu. Flipped to channel 7 and lo and behold, I'm reaching 74-75F and never get to the magical 79F. So I search, realize my t-stat is bad and decide to replace it. Job is pretty easy, I replace the metal ring, new behr tstat, etc. Car is reaching 81-82 now and I forget about it for a while. Fast forward to last week. Temps drop suddenly and we're seeing 32-37F daytime averages now so fall season is definitely over. Out of curiosity, i go into the secret menu and flip back to channel 7 - I'm dismayed to see 75F under highway cruising. In heavy traffic, it reaches 77-78 but as soon as speeds pick up, it never gets above 76. So is my t-stat bad...again?? In a year? I never did replace the temperature sensor on the top of the tstat housing - maybe that's the culprit? Thoughts? Dammit, tell me these things last more than a year. :eek7:
I see you did not replace temp sensors on top along with the t-stat. You prob didn't do the 2nd sensor either.. I was still having issues with mine after doing t-stat until i replaced both sensors.. the sensors were not expensive. 1 sits on top of t-stat and 2nd near radiator passenger side.. 2nd one by radiator was a PIA..
Replace the temp sensor/switch located on the t-stat housing.
...which is the one for the DME/cluster input. The one on the hose is for the aux fan.
Aux fan operation
Do our AUX fans have resistors on them that go bad over time like is common on the E30's?
Cause I think my AUX fan isn't working..
With A/C on, the auxiliary should be running. Speed of the fan is controlled by the DME, through the input from the
sensor located in the lower radiator hose (radiator outlet).
With A/C off and the radiator outlet temps become too high, the DME will turn on the fan.
Alan
^^^ Fan will not necessarily be on with A/C compressor operation, but should come on within a minute or so.
Yep.
1 - 10 of 10 Posts
