1 - 2 of 2 Posts
Hi all
Had a strange problem develop over the last two months.
When cold, engine will turn and then die just before it fires up. Always fires up second time I try to turn it on.
When hot (or even just after that first start), fires up immediately every time - no issue.
Scanned with INPA and PA soft - both reported crankshaft sensor. Got OEM and replaced (measured etc)
Same problem after changing. So now I'm not sure if it's even the crankshaft sensor any more. I can hear the fuel pump priming in POS II..
Anyone seen anything like this before?
S62 engine // 99 build year E39
My car which is a 7/99 EUR RHD build has the same symptoms. (I do not have any fault codes although my SAP is turned off and secondary O2 sensor faults disabled)
There is a very old post saying it’s the charcoal canister - but I don’t believe it is.
What I have noted with my car’s symptoms is:-
  • It won’t do it for weeks if I have previously charged the battery with a charger (the battery is 6 months old and had the same symptoms with 2 previous batteries).
  • If I turn the key to pos. II for 2 secs before cranking it will always start first time.
I suspect my issue is the unloader relay but I haven’t replaced it yet.
1 - 2 of 2 Posts
