Just wanted to chime in and say that it's been quite a while since I've participated here, however that is soon to change.
It's been an ongoing build process of almost a year. In the next couple weeks Ill be headed out to San Diego to pick up my car from Frank Fahey where the engine was just built. (B36/B38 hybrid)
Heavily Ported/Polished B36 head
Oversized SS valves
50mm ITBs
Honed B38 block
B38 crank
Pauter Forged Rods
10.25:1 JE Pistons & FF Spec Rings
New B38 Rod and Main bearings
ARP Studs and Bolts
Motorsport Valve Springs
VAC Steel Valve Ret. (Removed Ti)
Schrick 280 Intake and Exhaust Cam
FF Adjustable Cam Gears
55lb RC Racing Injectors
Secondary Air Delete
Header Jet Coated w block off plates
Stainless Steel Track Pipe
Uni Chip EMS (soon to change)
UUC Stage 2 clutch to go in
I'm very excited and will use this thread as a build thread to update the project as it all comes together.
