1 - 7 of 7 Posts
Having some trouble finding the right time part number. Looks like there are some different versions...?
I have a standard US spec ‘91 M5.
Thanks!
hello ! yes ! there are 2 part numbers .... the hub is the same ( i think) , but the ABS wheel is diferent for sure
check if you can see the part number on the part on your car... or check bmwfans , realoem etc with your Vin number
Does anyone know the correct part # here? Having difficulty figuring it out.
This will be the correct hub for a 91-M5 if the strut housings have not been replaced.
Wheel hub with bearing, P/N: 31 21 2 226 640, ABS-D=97MM, up to 11/1991,
If the strut housing has been replaced (one or both sides) the hub would be P/N 31 21 2 226 904, ABS- D=83MM 11/1991.
However the 904 hub is no longer available from BMW.
My preferred aftermarket hub as a replacement for the D=83mm ...904 hub is the SKF BR930349
The SKF hub is thick enough (same as OE hub) to be drilled to install the rotor pins removed from you original hubs.
Attached are some Images of the D=83 hubs for the M5.
It would seem the OE hub is made by SKF but they no longer supply BMW with the rotor pin version.
The FAG hub was sent to me by Schmeidmann as an M5 OE hub and of course it does not have the rotor pins of the original OE hub.
The SKF hub was half the cost!!
936065
936066
Thanks!
So can I measure some part of the hubs on my car to see which kind they are...?
The segmented section on the back side of the hub is the ABS wheel that determines which hub is needed for your car.
Early up to 11/91 should be D=97mm and after 11/91 should be D=83mm.
Unfortunately the hub needs to be pulled to expose the ABS wheel.
There may be another opportunity to compare the BMW part number on the strut as they are different between the early and late model versions.
1 - 7 of 7 Posts
