1 - 3 of 3 Posts
So i have been suffering from an intermittent cold start misfire
Only happens on coldstart and always affects cylinder 3
Misfire clears after around 10-20 secs and car behaves normally for rest of day
Garage diagnosed coil pack and plugs and changed this
Next day - problem remains
Now they are saying they want to try changing the injector
Questions
- where do i stand with the change of coil pack and plug? Should i expect a refund (they have not fixed the problem)
- injector seems plausible (under fuelling during from injector on over fuel cold start process?)
- what else could it be - wiring?
Should i try some injector cleaner?
Sounds like perhaps a leaky injector. Have you had it scanned for fault codes?
Questions
Stuff you can do for free to help isolate the issue:
Swap plug 3 to another cylinder (remember your choice) and see if problem follows.
Swap coil 3 with another coil (again, remember your choice) and see if problem follows.
If not, you have ruled out coil and plug. Do one at a time, to not confuse the situation further.
If the problem remains, then continue to dig into injector issues, etc.
1 - 3 of 3 Posts
