I was looking at the manual and it had 3 tips on there, one of them about whether it's a 6 or a b.. but I actually just assumed it was 69. I'll check it out again. Thanks.mottati said:i have a difficult time discerning if the code on the peak tool is a 6- or a b-, check to see if there is a b9 code in the peak booklet.
Mike
I better rtfm! i'm never sure if it's a b or a 6...ouichAnzir said:I was looking at the manual and it had 3 tips on there, one of them about whether it's a 6 or a b.. but I actually just assumed it was 69. I'll check it out again. Thanks.
If it is flakey, it may be setting the code, but not a 'hard, constant' failure. if it is bad for a few milliseconds, you'll never notice it- but it will be set. Once it fails hard you should notice the blatty exhaust and lowered power.Anzir said:Well, B9 is the dreaded exhaust Camshaft Position Sensor exhaust #1-4; yikes. Unfortunately, the code has been cleared but the more I think about it (I cycled through it a few times before I reset it) the more I think it was actually 69. And I don't have any of the typical symptoms... YET!Thanks again.
Interesting. I did that a couple of weeks ago and now I have an SES. How could WW affect it, just supposed to manage the heat better.XrayMD said:I kept getting that code after adding Redline coolant "wetter" and finally had to flush the coolant system and refill it to get rid of it.
:cheers:
Jerry-gsfent said:Interesting. I did that a couple of weeks ago and now I have an SES. How could WW affect it, just supposed to manage the heat better.
Thanks. I don't think you get air in the system simply by adding fluid to a cold motor. I can do a purge, no harm I guess. I have no other codes, only the 18/63. BTW, the Peake is a great tool :trophy_bronze: and very easy to use. Just make a copy of the code book, it is only slightly smaller than War and Peace!:biggrinbounce: :cheers:ard said:Jerry-
I saw that other post- pretty perplexing with the b vs. 6 thing...
I assume steve's comment above is regarding a true '69' code, not a B9... I seem to recall reading that the coolant system in the M5 can develop an air lock (this in the context of 'don't flush your own coolant, you can get air trapped and burn up the motor')... so maybe opening up the system allowed air in and the temp sensor is getting 'implausible' readings...
(You might also pull codes even if the SES is off- I **think** they can still be set, and not illuminate the light. In other words, you might not need to wait until the light is on if you are looking to see if the probelm is still there.
A)
A long shot- just mentioning a factoid I had picked up...gsfent said:Thanks. I don't think you get air in the system simply by adding fluid to a cold motor. I can do a purge, no harm I guess. I have no other codes, only the 18/63. BTW, the Peake is a great tool :trophy_bronze: and very easy to use. Just make a copy of the code book, it is only slightly smaller than War and Peace!:biggrinbounce: :cheers:
