1 - 12 of 12 Posts
Hi all,
Am about to order a new clutch for my 1995. I have noticed it slightly slip over the last two days so I'll take the genie's warning.
Apart from the Clutch plate itself, is there anything else I should have changed whilst having it done. Release mechanism etc? Would trawl through older post but don't have time today.
Best
M5 Powered
I always replace all three main parts. Pressure Plate, clutch disc, and throw out bearing. If there are wear signs you might want to do the release fingers, This ususally is not needed unless ther was some serious bearing failure. While its down you shoul d do tranny mounts and inspect driveline.
M5 powered said:
Hi all,
Best
M5 Powered
I would also do the pilot bearing.
BobZ
M5 powered said:
Hi all,
Best
M5 Powered
Are you fitting this yourself? When I had mine replaced at the dealership it cost £1400 inc a new sump gasket. Not cheap
Should be able to get it done for around £500?
If you can then great but the part cost just for the clutch came close to that with all bits i believe
Mine cost less than £900 when I had it done last at BMW - and that included a new flywheel!
Justed checked the invoice from Jan 2005:
M5 clutch kit £220
Labour (clutch and propshaft coupling) £225
Total £445 inc vat
Less 10% BMW car club discount
Thats an independant mind, not the main dealer
M5 clutch kit £220
Total £445 inc vat
based on that I think i'm gonna have to find a few independent specialists then
M5 clutch kit £220
Total £445 inc vat
What Specialist was it that you used? That price is very good, do you know what this garage charges for servicing....?
Hi Jon
I got my clutch kit from CAFCO at around £185. From memory the kit from BMW was cicra £225. Labour was about 2 to 3 hours at circa £40/45 an hour. I used Munich Motors of Wokingham, Berkshire.
Cheers
BC
1 - 12 of 12 Posts
