1 - 4 of 4 Posts
Is it possible to adjust the height of the clutch pedal? On previous cars, I'm used to it being at the same height as the brake pedal.
I've had it apart and it doesn't appear to be possible. I had thought I'd read somewhere that you could screw the push-rod into the master clinder (under the dash), but that doesn't seem to work
It's a 2001 car. Just had a new clutch under warranty (at 40k miles - thanks BMW :byebye:). Pedal was high before and after fitting. I forgot to ask the dealer at the time
TIA
Simon
I guess I dont remeber, but I will check when I leave for work, but I thought the clutch pedal was the same height as the brake pedal, will know soon, Josh
Mine is higher then the brake pedal, but I wouldn't know if that's correct or not since my car was purchased used.
allright I checked mine on my way to work, and it is indeed higher then the brake pedal but without measuring I would say only 1/4 on inch or less, so pretty close to even, however not exactly as above mentioned, how much different is yours? Josh
1 - 4 of 4 Posts
