First off I take no responsibility if you hurt yourself or your car while doing this.
Difficulty: Very Easy
Symptoms: My clutch pedal was rubbing the side of the plastic trim piece under the dash. I noticed it after my Indy had replaced the clutch line. The panel can be adjusted some, but my mechanic said new pedal bushings would fix the issue entirely. Others have reported squeeking with there clutch pedal, but I think it's more common in other models like the E36.
After a little research I chose to go with the Rogue Engineering. Rogue precision CNC's these out of Delrin, which is a Dupont product. According to the DuPont website "combines lubricity and wear resistance with the stiffness and strength needed in parts designed to replace metal." In our case it's not replacing a metal part, but the mechanical and self-lubricating properties are welcome.
Tools:
Flat blade and Philips head screwdriver
Sandpaper
Parts:
Bushings - 35211158290 (or equivalent)
Circlip - 07119905695 (optional)
(#s reference the parts diagram from realoem)
1.) Remove the lower trim panel by removing four screws and turning the two thumb screws. Then disconnect the two connectors.
2.) Remove the circlip (#13) from the shaft connecting the spring to the pedal. Be careful not to lose it. Then remove the shaft (#12). the spring assembly will probably fall off. This is ok just put it aside. (Note: My car does not use #9 or #10, I doubt yours does either)
3.) Remove clips (#5) and shaft (#3)
4.) Grasp the pedal (#1) closest to the pivot and pull it off the shaft. This was fairly easy to do with the stock bushings as they are not as tight as the rogue bushings.
For Rogue Bushings Only
5.) This is a little bit tricky as I discovered the flange on the new Rogue bushings was too thick to fit the Clip (#5) on the outside of the pivot point. So some material would need to be removed for proper fit6.)ment. Take a measurement of the pedal width at the pivot point (including the old bushings) and mine was approximately 41.88 mm. I took several measurements of the flange of the old bushings and the new the old were anywhere from .053-.059" I believe so you need to at least get the new ones under .060" (using sandpaper or a lathe if you want to be overkill). We also took some sandpaper to the side of the clutch pedal (VERY LIGHT) because the pedal is a molded part and there is a seam that the old bushing sat inside that the new one sits on top of.
6.) Install the new bushings into the pedal and ensure the measurement is very close to the original.
7.) Reinstall in reverse order. Even though the bushings are self lubricating I took some WD40 and sprayed a little on my finger and rubbed on the pivot point shaft. This is because the Rogue Engineering bushings are machined to a very tight tolerance and made install of the pedal to the pivot point a little easier.
Impressions:
Worked like a charm. Also seems to improve clutch pedal feel (although that could all be in my head).
Tools:
Sandpaper
Parts:
Impressions:
