I am a little bit puzzled. Ive replaced mostly front end to fix the shimmy, and worn out parts. When you either stab or release the braking quickly at low speed, it can be felt. I am very sensitive on how I can feel something if it is off. Being deaf definitely heightened my other senses pretty well.
I am thinking Febi stabilizier end links might be the cause for the clunks. How do I check for knuckles to determine if they are ok.
I replaced
-OEM Tie rod ends with center drag link (installed last year)
-Lemforder thrust arms with powerflex black bushings (installed last year)
-Febi stabilizer end links (Installed a week or so before timmayfest trip)
-Front rebuilt calipers along with new brake rotors/pads (Installed recently on calipers)
I replaced
