1 - 7 of 7 Posts
I'm getting a clunking sort of noise from my right front suspension. I was wondering if there were any common problems with the bushings or bearings going bad. Can i inspect anything for wear? Btw, my car is a 99 540i/6 lowered on full coilovers with 19x9's in the front.
Best way to diagnose is to get the car up on a lift and use a pry/crow bar and start moving things around. That will show if something if loose or if something is moving that should not be moving - Good Luck!
hi
ok i got it up on my local garages ramp and checked all joints and all the axle supports are totaly fine,cant see anything , this knocking is happening when i brake from 5 mph to 0 mph knock knock every time i press the pedal!
i checked the brakes,even took of the calipers and disc and pads etc and nothing apparent,is it possible to get a knocking noise from the brake piston???
:1zhelp:
1 - 7 of 7 Posts
