6601 - 6620 of 6621 Posts
Hey Clemster, was sent your thread here by a fellow E39 friend, curious if you had any of the nav brackets (51457044007) currently? Would be shipping to GA.
Cheers!
David
Discussion Starter #6,602
Hello, David. I have these and sell them for $30 shipped. However, I am away from the shop until the 14th. Check back them if you still need it.
Adam
Adam, it's been awhile. Hope all is well man!
Any chance you have an M mobility unit/kits available? Air compressor is mainly what I am looking for
Discussion Starter #6,606
What's up, Jon! I have several and sell the newer style (2001 and up) for $40 + shipping. I test the pumps on all.
Hello, do you have an e39 M5 rear sway bar? Thanks.
I have more than a dozen stock 16.5mm sway bars available for $50 each + shipping/fees. Another $20 for OEM bushings and brackets.
Clemster, looking for a trans shipped to 60148.
I have 3 available at the moment, but one is pending sale locally. Price range is from $500-700 + $150 flat fee UPS ground shipping. Message me if you would like more info.
Ah I got one already, no worries. Hope all is well, stay safe
Discussion Starter #6,610
Do you have any e39 m5 x pipes?
I do have a Supersprint but it's paired with Remus mufflers and is pending sale locally. If it becomes available, I'll message you. What's you location? Shipping cost is impacted by distance (I'm in MD).
Driveshaft CV joint ?!!
You'll want to go with a new one. Good used CV joints aren't realistic.
Any of the darker nussbaum trim pieces for the drivers door, passenger side dash and (really doubtful) the center console in decent condition?
Adam - it's time to do some long-neglected updates on my 2001 Carbon Black, hope you can help me out. If you recommend that I buy some of these items new instead, let me know and I'll add them to my list.
1) all of the plastic underbody panels, along with the hex-screws and clips that the screws go into. I replaced my old ones with steel skid plates, and decided I want to go back to stock. So - panels, clips, screws. 51712498988 (front engine comp. screening), 51712498987 (underflood coating panel), 51718158060 and 51718176757 (lateral covers), 51712499999 and 51717016562. Don't need porkchops.
2) whatever parts might help with the fact that my alarm and my lock/unlock don't make noise. I was thinking maybe the siren (65758383153 or some other speaker???)
3) plastic trim pieces from the driver's seat, that sit around the rail where it mounts to the floor. 52108217291. Somehow my seat got caught on them and cracked them.
4) front plastic cowling between the hood and the windshield that is flaking. I think its 51718159292, but you may know better than me.
5) the leash that connects the gas cap to the car.
6) windshield and intensive fluid caps, 61667467951 and 61661369516
Please and thank you,
J
Zip: 33704
Hey Adam, I believe I need a VANOS pump for the e39 m5. Bank 2 sounds worst than a diesel track. I put new "O" rings and spanner disc in it, still no change. I have a bank 2 Vanos Function Code; given the noise it's putting out, I believe the board is faulty too. Do you have one?
Hi Adam! Back again. Do you have a pair of front bumper shock absorbers (holding bumper, not suspension), p/n 51118172389, -90? I need a pair that allow the captive nut inside to rotate to adjust the bumper height. Mine are rusty crusty and won't budge. Thanks!
Hey Adam I need wire harness that illuminated shifter plugs into
shifter boot with a good bracket since I am transplanting f10 m5 shifter boot onto it
some clips that secure door/dash trims (also need a few of the pins that are
need screws and hardware to secure belly pan and pork chops
also wanted to know if you have any dead pedals and some nice pedal covers.
thanks again
Discussion Starter #6,617
Sorry for the delay, guys. Vacation set me back and I'm just starting to catch up.
Won't have a crack free console piece. Will message you pics of the trim after I search through the stash.
J
Zip: 33704
J,
Unfortunately I'm depleted on good belly pans, trans covers and the two lateral panels.
I do have 51712499999 and 51717016562 for $35/pair.
Alarm siren #65758383153 $25.
I'd recommend buying new seat trim (52108217291). It's still cheap and new ones look great.
Same with the cowl tray. Used ones aren't usually great and they are tough to ship due to length.
$2 each for the filler caps. Don't have the tether.
All of it for $84 shipped.
I don't sell the pumps separately but have vanos units for $275 each and good solenoid boards for $450. Would do both for $700.
No luck yet. I lube a set with Aerokroil and will try them tomorrow. All my others are hard stuck.
thanks again
Hey Adam,
Curious if you were back in yet?
David
Yes I am. Can help you with that if you still need it. Shoot me a message.
Reactions: jonesymalone
Hi Adam,
I have a 2001 E39 M5 Imola Red with Black/Red interior. Mainly, I'm looking for :
  1. New Condition headlight assemblies - mine are terrible and restoring isn't working
  2. Front Driver Seat leather - Black/Red seat leather is so hard to find. My red insert panels are fine. I would buy all-black seat leather and take the car to an upholstery shop and replace the red insert leather with mine.
    1. Suggestions?
  3. Steering Wheel
I might create a list of other items, but this is the current wish list
Cheers,
Frank
[email protected]
