1 - 4 of 4 Posts
I was trying to figure out if I should just replace my lights since they looked terrible so I decided to try "restoring" them first . The top picture is after and the other is before and each headlight took about 45 min. each.
Did you polish with the headlights intact or remove them out? I still have to do mine as well.
Make sure you apply a coat of headlight lens protectant.
Reactions: caliboy951
Yes very important to apply a protective layer otherwise you'll be back at square one eventually. I had mine wrapped in a clear bra after I had my headlights modded by Chris at Republic Wraps. Another option that is getting very popular is the opti-coat for headlights I heard it works excellent, cheap and easy to apply.
Optimum Opti-Lens Permanent Headlight Coating, headlight coatings protectants
1 - 4 of 4 Posts
