1 - 9 of 9 Posts
I'm feeling kinda stupid for asking this, but I can't seem to adjust the climate control for hot/cold air on the passenger side in the climate settings. I can adjust the setting for the driver using the i-Drive controller, but the passenger is set to cold and I can't adjust it :confused:
Discussion Starter #2
Attaching a couple of pictures:
Driver side set to "neutral"
Passenger side stuck to cold
I checked the Climate control on a friend's E70 with CIC and I could adjust the temperature setting on the passenger side there. Can anyone confirm if they can or cannot adjust the passenger side temperature on their E60 CIC?
I feel like I just was messing with mine and it worked fine... I'll try and mess with it again and see how I did it.
Generally you should be able to adjust it by just turning the i-Drive knob.
Shameless self bump...
EU spec cars get the CIC in 2009, it's not a retrofit.
I think that might be the default behaviour on E60... I have a Combox retrofit, which I believe required a certain firmware version to be flashed to the CIC and that's probably why I have an active passenger climate control.
1 - 9 of 9 Posts
