1 - 20 of 30 Posts
I'm selling a CIC retrofit kit for E60 M5s or any other E60. It comes with 9 parts total - the only thing I don't have is the emulator but those are ~$50 on ebay:
1. CIC Navigation radio (Used)
2. CIC Navigation 8.8" HD screen (Used)
3. CIC Navigation Controller (Used)
4. Glovebox USB port 84109237656 (New)
5. USB Cable to connect USB port to radio 61129255716 (New)
6. Display Cable to connect HD monitor to radio 61119185171 (New)
7. Radio faceplate trim with 1 DVD slot to accomodate CIC radio and LCI climate controls. 51456976361 (New)
8. 8 pin connector for HD Screen power/CAN wiring (61136954526) (New)
9. 4 pin connector for CIC controller power/CAN wiring (61138377238) (New)
Depending on how you want to install the new controller in the center console I can also include the holding bracket parts for the CIC ontroller.
This will not require any kind of coding or programming to work properly once installed. You'll have to do the installation work to install the parts but once everything is in it will work for your specific VIN, out of the box as you receive it without any extra coding needed.
Pics:
Asking $1,000 shipped
PM me or text me @ 248.631.4914 if you have any questions
Pics:
I'm assuming you need a different trim to fit controllers yes? 09-10 models I assume?
what else would I need for my 08 M5?
Sorry for the delay, was doing some Labor Day camping :)
Being an 08, you are pretty much set. The only things are mounting the controller in the console and emulator. Either you have to modify the console to the new controller shape or just get a 2009/10 console trim.
Bump for good seller and was very helpful
Sent from my SM-G955U1 using Tapatalk
Thank you for the kind words!
Do you have the link to the emulator that needs to be purchased?
Sent from my LG-H830 using Tapatalk
I usually get them on ebay here:
https://www.ebay.com/sch/i.html?_odkw=e9x+cic+emulatort&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.A0.H0.Xe9x+cic+emulator.TRS1&_nkw=e9x+cic+emulator&_sacat=0
How would I be able to make this work on a 2006 E63 M6?
For the 6 series there is a little more that is needed. In addition to this you would need a center dash trim to match your trim and a center console from a 2009 or 10 model with your same trim. The 6 series parts are all trim matched and the console needs more than just a trim piece to make the controller work unfortunately.
Discussion Starter #15
Apart from cosmetic modification to the centre console, is there anything technical that would prevent it from working in an 06 E63?
Functionally, no.
The biggest hurdles are the center radio trim and console when it comes to the cic retrofit in the 6 series.
Tried to PM you but given my lack of posts, I've been thwarted yet again!
Can you please try to PM me with an idea of postage to Australia?
My postcode is 0810 in Darwin NT.
Cheers!
Hi, can you send me a message in private mode?
How much for shipping to Brazil?
Zip code: 71.110-600
thanks!
shipping?
Hi, can you send me a message on private mode?
how much for shippning to Brasil?
zip code: 71.110-600
1 - 20 of 30 Posts
