BURTON said:What are the Options for a Guy like me who has a SRS type wheel?
:flag:
Hi - I just got an LE and my 3 spoke wheel has an airbag but the rim is large and I think a smaller wheel would be better. Ideally something like the sterring wheel from the M3CSL?BURTON said:Can anyone point me in the right direction as my wheel feels to thin and big and is worn, so the leather is looking more like Plastic.
Well Rob, for me I would want some kind of Airbag control. I know an Airbag wheel would cost a mint! but it whether they could be controlled from an older system..Rob Plummer said:That standard wheel REALLY is sh1te
Ditching the airbag wouldn't worry me personally.
Sounds like you have some put some research into this, or know something as a BMW tech? I know its far fetched.. And hardly worth the effort. But a CSL wheel is nice!540is said:And no - I have not tried the airbag functionallity - so I better put a disclaimer before getting sued, do not try this at you car !
DIY E36 Euro Steering Upgrade ProcedureBURTON said:Think I might just order a E30 m3 Evo with the suede rim.
If your car is a pre 91 then an e30 wheel will fit straight on as it shares the same steering column. If not then you're options are anything that fits an e36 column (provided you change the indicator stalk mounting bracket + either deactivate the airbag system or wire in the e34 adaptor to the e36 slip ring).BURTON said:Rather have one that would fit straight on!
Actually thinking about it, your car has an SRS airbag so the e30 wheel almost certainly will not fit without changing the steering column.Tubbs said:If your car is a pre 91 then an e30 wheel will fit straight on as it shares the same steering column. If not then you're options are anything that fits an e36 column (provided you change the indicator stalk mounting bracket + either deactivate the airbag system or wire in the e34 adaptor to the e36 slip ring).
