I took the old ones off, removed the caliper gave it a good clean.
Fitted everything back together as it should go.
Now, I have this light metallic noise if I turn the wheels. Ive checked everything, cant see where disc is rubbing at all.
Is this common for when brakes are bedding in? What can it be?
I have tightened everything to the correct torque settings aswell, used copper grease where it should be used.
Brakes work perfectly though, just the light metallic rubbing noise.
