1 - 3 of 3 Posts
UPDATE: Finished wrapping the instrument cluster and it came out good. I ended up not cutting the front clear plastic and instead installed it from behind using a thin square piece of vinyl tile that had a sticky back that I cut in pieces then wrapped and fit in the areas desired. It was a bit time consuming to get it just right but not too difficult.
Attached is a pic of 2 of the 4 pieces of vinyl tile I cut with a razor and end results.
I’ve been hooked on wrapping lately and ended up wrapping a ton of the plastic interior trim pieces to match the stock look since the rubber coating on all the plastic is was peeling off.
930485
930486
930487
1 - 3 of 3 Posts
