1 - 6 of 6 Posts
Hello everyone,
I'm having an issue with the check engine light on 2012 F10 M5.
Dealer said I need to change all 8 injectors as they "think" this will fix the problems?
Took it for a second option at another BMW specialist they seem to think its the Oil separator which is an equally expensive repair also they mentioned some leakage from the fuel pump,
I would greatly appreciate any information or assistance,
Thank you
We can't help you without more details... things like what the codes are. No one can give an accurate response without knowing more about the symptoms and codes in the ECU's.
Thank you very much,
I was not aware of that.
I will look into it👍👍
Living in Duabi so hopefully the warranty is the same🤞
1 - 6 of 6 Posts
