Carsoft 6.5 OBD1&2 READ/ERASE/RESET CODES+MORE 4 SALE
4285 19
Brand New, you can do much more than a peake tool. You may read live data, read/erase/reset codes, reset service intervals/oil and airbag lights and much more!
- Works for 3/5/7-series including M, z3/z4, X5/X3 and others!
Any questions feel free to ask.
$140 SHIPPED !
OR check it on Ebay: http://motors.search.ebay.com/_W0QQsassZ2elite4
More info:
All BMW Vehicle Types from 1988 to 2005
- READ AND ERASE Error codes of various systems like DME, ABS, AIRBAGS, EGS, etc
- RESET Service indicator light
- RESET Adaptation values of DME and EGS (Automatic Transmission)
- PROGRAM features like auto-doors lock on driving, selective locking
- READ live data from DME / DDE / EGS
- SYNCHRONIZE EWS and DME in case of a malfunction
- WORKS on E30/E31/E32/E34, E36/E39/E38/Z-3/Z-8, E46/E53 series
1 - 20 of 20 Posts
Why does it show $140 shipped on ebay?
i bought this 2 weeks ago and had no problem synching with the car. I got a bunch of codes, some in german it seemed like, and now it's in the shop. i cleared the codes and the ses light came back on the next day. it seems to work as advertised... the codes are hard to interpret though/
Discussion Starter · #9 ·
Message me your problem and I'll be glad to guide you through.
PM sent how to fix this.
I bought this set up and still havent been able to get it to interface with the car.
Ryan
Almost a month later I see this....
Ryan, if you haven't already, only use the diagnostic connector under the hood-the port under the dash won't work on a MY2000. I had the same issue with mine, then plugged it in under the hood and it works perfectly.
Any idea if it can program the car to roll windows up on press&hold lock? Also, can mirror flip up and down be programmed for lock/unlock?
Matt
Reactions: savage
Super Moderator
I. Finally got to try this and have some troubles when I try to scan, the program give me a message "carsoft has encontered an error and will now close, and error has been stored". It does seem to sync with the car to do coding. Any thoughts?
Super Moderator
ok, well, the coding apparently doesn't work either. Tried to code for 'auto door locks' carsoft went thru the motions, and says my car is coded for it, but when i drive away, the doors don't lock.
Input appreciated, pm sent.
Super Moderator
seems to be working now with the new software, thanks.:cheers:
spoke a little too soon. Yes it scans, no it does not program autolock function, nor does it change the languages. It says i now have auto lock active, but they don't auto lock.
also says i'm in german language (just fooling around with it) but my obc display still is in plain old us english.
1 - 20 of 20 Posts
