Carbon Fiber Diffuser & Custom Exhaust Tips
31770 36
A fellow member...(Hey Diny!)...requested photos of my new carbon fiber rear diffuser setup with new Flo Pro quad 3.5" tips which are slightly bigger than the previous tips...I'm running a Britalman x-pipe and Borla XR-1 race mufflers, sounds similar to a x-pipe/Kelleners setup maybe a bit deeper.
For those wondering...yes this is the Ebay CF diffuser (that I then modified)...quality is pretty good but the tabs need to be carefully modified/sanded with a Dremel to fit correctly, its like 97% there in terms of the fit.
Thanks! :)
1 - 20 of 37 Posts
Very nice...G and i love the blacked out emblem :cheers:
Nice! I like what you did with the center piece as well, nice adaptation from your previous diffuser.
I like the tips, too! Are they the same style as the ones from your previous setup (but bigger)?
Got a link to ebay for the diffuser? I know some people have had major problems with diffusers off of ebay.
Hotness. Next time I'm in Atlanta, I want to look you/this car up...:thumbsup:
Dave
Discussion Starter · #16 · (Edited)
Thanks! :cheers:
I actually bought the CF rear diffuser a long time ago...can't remember the exact seller on Ebay, but it was the only seller from Atlanta that sold carbon fiber stuff...not sure if he's still around.
To my knowledge there might be two different (or more) makers of OEM style carbon fiber diffusers, some might fit better than others but not really sure.
I'm used to using a Dremel, so I was able to modify it to fit pretty good by sanding/grinding the tabs just right, might could use a bit more work to fit flush on the top horizontal seam but it is workable.
As for the jet black M5 logo on the trunk...I bought a replacement factory badge that was then carefully taped off and painted by my body shop...then I put it on...turned out pretty nice.
I need to get a sound clip of the exhaust...sounds pretty wicked. :)
G: Makes me drool every time lovelove
BTW: Did you DIY your blacked-out M5 emblems?
Discussion Starter · #20 ·
Thanks...the blacked out M5 emblem was actually done by my body shop in jet black and clear coated...I could have done a DIY but it would have been more like a flat/satin black.
1 - 20 of 37 Posts
