21 - 29 of 29 Posts
I can confirm win10 works fine for INPA and ISTA-P. I coded my off my win 10 laptop but its all in german and i cant find the english versions of the software if there is any
All programs should run fine with XP or win 7. The only program that will not work on win8/10 is NCS as it needs to run on a 32bit machine.
As far as being able to connect to the car, you'd need the USB drivers for XP.
Sent from my mobile. Pls excuse brevity and spelling
Sent from my EVR-L29 using Tapatalk
have the interface set to std:eek:bd and the correct port (COM 1)
I'm waiting for my BG cables before I go insane trying the same thing over over again lol.
I know it's not my settings or else it shouldn't work on my Mini and X5.
I am getting
NET-0015: HOST NOT FOUND
with Rheingold when I try to do the vehicle identification.
INPA dots show up and respond when I turn ignition on/off. I followed the instructions from that thread.
There is another set of config files in another folder. Make sure you repeat the respective configuration in those as well.
Thanks guys, I copied the EDIABAS.ini from C:\EDIABAS\BIN to C:\RHEINGOLD\EDIABAS\BIN and everything works fine now. The EDIABAS.INI in Rheingold was totally not set up for kdcan.
21 - 29 of 29 Posts
