Can anyone's M5 play MP3s on CDs?
2472 18
The owner's manual is a bit vague but mine can't play MP3s on a CD in either the stacker or the single CD player in the cabin.
1 - 19 of 19 Posts
Discussion Starter · #7 ·
Chris, I have iTunes on a mac too - are you sure you made MP3s? Some of the iTunes function actually makes a standard CD from your playlist.
Can you explain how you made the CD with iTunes?
chris.bailey said:
Mine does have Nav Pro. Have burnt discs using iTunes and they work fine (though I am not a lover of MP3).
I also have Logic7 so maybe that makes a difference.
Then yours must be the only one in the world
We have hundreds of pro nav owners on E60 forums waiting for MP3 software, and BMW Germany confirmed it will ony come out in CIP21 in October/November
Discussion Starter · #10 ·
chris.bailey said:
Defo MP3 Cd as that is the way my Itunes is set-up.
Hi Chris, Just burnt 3 CDs from iTunes and no luck. Can you advise:
1. How many tracks do you have on your CD?
2. Are they all in folders at the top level?
3. Are you burning from iTunes mac or windows?
Thanks, Syd
for what it's worth, my SLK55 also has a harmon kardon Logic7 with a glovebox 6-changer + 1 headunit drive which seems to be the same config as the one on the E60 M5. Since it's the same manufacturer with the same logic7 electronics, I'd assume it would play the same type of media. It plays MP3 CD-R/RW's as well as MP3 DVD-R/RW's on the headunit but not on the changer.
Makes a change as normally I get something that wont do what it should ??????
Will re-check when I get home this evening :confused3
I tried today to play MP3 Data CD made in Both Itunes (mac) and Windows Media playeer. I tried the disk in Changer , In Dash CD and DVD it wasn't recognised or played in any of them, asked dealer today about it, they didn't know but said they would check.
I can confirm that I can play MP3 files on my July build M5, made the disk using Windows media, have not tried it in the changer but works a treat in the one above the DVD slot, I too have Logic 7 if that makes a difference? Only problem is that my Itunes is set to AAC, so I will have to reload any music i want in MP3 format.
Discussion Starter · #15 · (Edited)
MPWR said:
I can confirm that I can play MP3 files on my July build M5, made the disk using Windows media.
Thanks - what version Windows Media Player? On XP I presume?
Are you sure Media Player has made a CD with MP3s on it? If you select Burn Playlist it will make an Audio CD that plays on standard CD players and not a data disc with MP3s on it according to Microsoft (http://www.microsoft.com/windows/windowsmedia/player/9series/howto/burningmixCD.aspx)
To check, try and make a CD disk with more than 80 mins of music - if it makes standard audio CDs you'll get a 'wont fit on CD' error. (http://www.microsoft.com/windows/windowsmedia/player/faq.aspx#7_5)
Do you have Professional Naviagation ?
"Burn" makes an audio CD (uncompressed WAV). To put mp3 files on a CD, you do not use Media Player but just Windows Explorer and drag and drop them from their source location to the target CD burner. If you don't have mp3 files, you can "rip" them from an audio CD.
Tom
Yes you are correct, I have just checked the CD and it did create a Audio CD, have since tried using MP3 files and it did not work!
1 - 19 of 19 Posts
