1 - 6 of 6 Posts
I had been using the Castrol TWS 10W-60 Motorsport (and its successors Castrol EDGE 10W-60 Professional and Castrol EDGE 10W-60 FST) for more than 10 years without any (noticeable) problems. For my last oil change the Castrol was not available and as I had read in different threads that it is anyway not the best oil (although it is the recommended one by BMW), I decided to get a new one. I was recommended the Motul 300V 20W60 or the Motul 300V 15W50 and saw that people online were using and having good results with those. I went for the 20W60 and I've had it for a couple of months now.
Last week I got smoke from the car. I stopped and saw that there was oil all over the engine. The car was brought to the garage and they told me that a high pressure line (not sure which part it is) was the problem. I still haven't got the car back but I started thinking if the thicker oil could have caused that. Or is it just the ageing of the car (it's now 15.5 years old)? What do you guys think?
In my opinion it's a line failure and nothing to do with the oil properties. The "cold" side (10W, 15W, 20W) of multi-viscosity oils aren't that much different. The "hot" side (-50, -60) is measured at 100C; at this temperature a 10W-60 and 20W-60 oil will be in the same range of 21.9<26.1 centistokes (cSt). Probably first thing you need to find is where the leak is. The VANOS system pressure is much higher than the engine oil pump pressure.
What broke sounds like the vanos high pressure line to the vanos regulator, they break frequently(based on group of cars not one car). As a guess from posts 1 in 10 have this failure. It is a part I replaced at 200k km just so it did not break.
correlation != causation
The line runs at 100 bar, I'm surprised they don't fail more often. Mine went in January of last year; other than the mess, it's not a big deal.
1 - 6 of 6 Posts
