1 - 4 of 4 Posts
crmcinco said:
Has anyone changed the bulb on the front turn signal light?
1) The owner's manual has instructions on how to replace the bulbs.
2) I believe you can do this from the back without removing the headlight assembly - but if you need to remove it, it is easy - two screws up top and forward, two more behind and low (use a flashlight to spot them - hex head screws - don't drop them!)
They're virtually impossible to access without removing...especially the passenger side...but as Greg suggested the headlamp assembly is easily removed.Ensure you mark their positions for correct headlamp replacement and a magnetic socket is essential for the lower screws...if you drop one as I did recovery is almost impossible as they land on the underside engine shroud.
You may wish to consider a small dab of silver paint on the outside facing face only.
1 - 4 of 4 Posts
