I recently bought some used angel eyes from a member, and the both headlight adjusters were broken. Im wondering if this is a common problem, and should I avoid buying used angel eye headlights?
If you are not aware of this problem, you can check it, if you try moving the projector from the rear, where the bulb is, if it wiggles around freely, its broken.
Should be covered under warranty.
tia
tia
