Vivid Racing is one of the largest Brembo brake dealers in the USA.
All Brembo big brake kits include street pads, steel braided brake lines, 2 piece floating rotors with patented McLaren hardware, calipers, brackets. The patented McLaren hardware is only used on Brembo kits and this allows the rotor to have a true center line for better pad wear, improved heat dissipation, and overall longer rotor life. The increased veined rotors also help tremendously reduce brake fade.
All Brembo kits are available in RED, SILVER, BLACK, or YELLOW calipers. We can do custom colors for an additional cost. Rotors are available in your choice of drilled or slotted. We recommend slotted for the track guys.
Front:
-Brembo 6 piston monobloc 380mm 2pc Brake Kit
-Brembo 6 piston monobloc 405mm 2pc Brake Kit
Rear:
-Brembo 4 piston monobloc 380mm 2pc Brake Kit
PM or CALL 480 966 3040 ext 228 for your M5board member pricing!!! :M5thumbs:
Front:
Rear:
