toxicfrog said:
Hi All,
Just checked the pads in prep for my trip to the Ring on Friday - I wondered if any of you had any recommendations for aftermarket fast road pads? Be nice to install a set and take the existing set as a spare (theyre not that old) - or are the BMW ones sufficent?
Cheers
Paul
Paul
Has yours got the floating brakes & 4 pot calipers ?
If so then all should be well & pads are not so much an issue as the huge rotors dissipate heat better anyway.
If you have the single pot sliding caliper of the earlier models then I would dump the std pads & get some Pagid pads or similar & maybe a change to synthetic brake fluid (dot5) which has a higher boil point.
Depends how you are going to drive really but BMW pads are quite soft generally.
I would check all the exhaust hangers especially at the rear & replace if perished.
Tape up your fog lights at the ring. I have lost a couple there so I always tape now.
I run tyre pressures at 39 to 41 frt & 43-45 on the rear.(My preference)
In addition I take :-
5 spare litres of engine oil & a bottle of CHF11 S hydraulic levelling fluid.
I spare coil pack module & 6 spark plugs. (I know it sounds daft)
Have a great time & take it real easy for the those initial laps.
Farrell
