81 - 100 of 169 Posts
AHA! So in essense, I can run e32 750IL 4 pot calipers part number 34 11 1 159 775 & 776, WITH 324 mm rotors? Along with a decent set of PADS, I should do quite well.
NOW, aren't m5 rotors 342mm?
If i have the e32 calipers, can I still run my 16" winter rims?
ok, since i just put a set of 750iL junk on my car....
750iL 4 piston ATE calipers (HEAVY!!!!!!!!!) use the 324mm rotor
stock M5 is 315mm.
I also pulled the 15 inch 750iL wheel off the very same car i removed the brakes from to use as winter wheels...
I'm using ATE pads at the moment just to get the car back on the road, but i would love some suggestions for good pads and discs others have used
As Bubba996 said earlier, this site http://www.bmwe34.net/e34main/upgrade/brakes.htm has what looks like a thorough list of BM rotor and caliper options for an E34. I can't find a 4-spot caliper from an E32 listed there. If you found an E32 4-spot caliper and have the part number, can you post it please. If you want 4-spot calipers on an E34, this page recommends fitting 840/850 rotors (324mm) and 840/850 4-spot calipers. BTW, the caliper part number in the table for these parts has a digit missing, it should say,
34 11 1 161 177/178 (the "1" after the "6" is missing)
and according to the ETK, they are a Brembo caliper.
Correct me if I'm wrong, but it also says the E32 calipers are matched with 302mm rotors, which are smaller than the standard 3.6 M5 rotors (315mm), which doesn't seem like a step up to me. Could be an increase pad area I guess, but increased rotor size should provide more stopping power for the same applied force; correct ?
It should be noted that the info on that page for E34 brake upgrades using factory BMW parts was written mostly by Rob Levinson (of UUC Motorwerks). As such he was probably going by what's available in the US. Only reason the E34 floating rotors are mentioned is because he has an M5T that had 'em on it.
And I think that the E32 750 4 pot calipers weren't available on any US E32 model. Which is why those particular calipers weren't mentioned in that writeup. In fact, I've heard that those E32 4 pot calipers are quite uncommon in any pats of the world.
Haven't been to the ring, but work great on repeated high speed autobahn runs. Need a bit of heat and make a bit of noise. But freat initial bite and no fade as yet. When I get the car back on the road I'll be off to the ring or the alps for some anti-diesel-mondeo therapy!!!
Both are a direct bolt on to any M5.
FCP857 are for the single piston, M5 with 315mm disc, E32 and E31 also (with varying disc sizes - 302 and 324mm I think.
FCP578 fit a whole host of single piston rears.
The front pads (for the 345mm disks) are loud and clear! :) But for my '95 Touring (with the 4-piston front brakes) I also need the rear pads of matching compund (DS 2500) for my 328mm disks. According to realoem.com the brakepads are "unique" for the M5 with the 328mm rear disks. So, which part number is the correct one? Is it really FCP578?? :confused: :confused: :confused: :confused:
It's understandable that the pads are specific to the big brake M5 and 850 CSI, However the rebuild kit for this caliper is the same as for plenty of brakes. - Including 3.6 M5 and E32 750il.
So I would guess that the caliper is the same apart from the radius of the Mounting holes (as per the 750IL/M5 caliper).
So I would sat 'yes' FCP578 is the correct pad.
Understand your frustration, it took me a long time to find the correct pads - including the guy at Circuit Supplies (see earlier post I think), sitting with me with photos, catalogue and a ruler!!
http://www.realoem.com/bmw/partxref.do?part=34211158578&showus=on&showeur=on
:cheers:
A Pad Table Perhaps ?
Sounds like my table in post #48, needs a couple columns for pads too or we we need a pad table !
Any preferences for which ?
Reg
Mucking around with brakes shouldn't be done unless you know what you are doing - AP and MoveIT have kits for the E34 so are a good place to start.
I mucked about with my Bi-Turbo brakes, fitted the Brembo 4-pots and 324mm discs and they were horrible. Long, longggggg brake pedal, driving the car slowly was possible but anything that required me to stamp on them, meant in reality 2 stamps, so they performed badly and were dangerous.
I changed the master cylinder, bled, bled and re-bled everything but the fact was, these brakes were not designed for my car so I went back to standard with new discs.
It always sounds like a great idea to have bigger better brakes but I've learned through my own mistakes that to beat BMW I have to study harder and just to use the parts bin might not work.
AP would be my favourites, or 3.8M5 brakes in your case (but not on 16's if I remember correctly)
Cheers,
Dave.
Great thread. I believe that we need to merge my Brake talk thread with this one.
ANyone can verify this? Doesn't make sense to give smaller breaks to a country "obsessed" with safety.
Reg
Great suggestion! If you wanna do the job, I suggest a separate pad table and I also have a few suggestions fir the table: Stock, stockish (maybe 2 different brands), Ferodo (both DS 2500 and DS 3000), Pagid (2 or 3 options maybe) and maybe PF (Performance Friction). That is, if we want the quality stuff... :)
:cheers:
Thanks a bunch! I owe you a beer! :D Are you going to the Goodwood Festival of Speed by any chance?! I am; plane tickets, hotel and festival tickets are all "CHECK"! :D
OK, hold on a minute.
Just cross referenced EBC, looks like the pads for 328mm rears are 123x59x16.8
for 300mm rears they are 123x44x16.
Page 14
http://www.ebcbrakes.com/Assets/2004_5USAautocat.pdf
<table x:str="" style="border-collapse: collapse; width: 66pt;" border="0" cellpadding="0" cellspacing="0" width="88"><col style="width: 66pt;" width="88"><col> <tbody></tbody><tbody><tr style="height: 12.75pt;" height="17"></tr></tbody></table><table x:str="" style="border-collapse: collapse; width: 66pt;" border="0" cellpadding="0" cellspacing="0" width="88"><col style="width: 66pt;" width="88"><col> <tbody></tbody><tbody><tr style="height: 12.75pt;" height="17"></tr></tbody></table> <table x:str="" style="border-collapse: collapse; width: 66pt;" border="0" cellpadding="0" cellspacing="0" width="88"><col style="width: 66pt;" width="88"><col> <tbody></tbody><tbody><tr style="height: 12.75pt;" height="17"></tr></tbody></table>
Page 14
Hmmmm..... Looks like my first suspicion was correct.... ;)
The EBC pad looks alot like the Ferodo FCP 857:
http://www.elcome.co.uk/fmecat/fsp/CarSpecs.asp?pn=FCP857
I am aware that the measurements are not 100% identical...
The Ferodo FCP 578 is completely different:
http://www.elcome.co.uk/fmecat/fsp/CarSpecs.asp?pn=FCP578
So, who knows for sure? Who tried them?
Proposed Table. I've done EBC as an example because the post from "GoneAgain" was the last post when I started and access to the info was easy. Can look at others as time permits.
Any feedback as to how this could be improved, would be welcome.
While it's easy to do this from catalogues, what we really need is someone to verify any combo they've actually used.
<TABLE style="WIDTH: 748pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=996 border=0 x:str><COLGROUP><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 585" width=16><COL style="WIDTH: 125pt; mso-width-source: userset; mso-width-alt: 6107" width=167><COL style="WIDTH: 84pt; mso-width-source: userset; mso-width-alt: 4096" width=112><COL style="WIDTH: 95pt; mso-width-source: userset; mso-width-alt: 4644" width=127><COL style="WIDTH: 47pt; mso-width-source: userset; mso-width-alt: 2267" width=62><COL style="WIDTH: 27pt; mso-width-source: userset; mso-width-alt: 1316" width=36><COL style="WIDTH: 37pt; mso-width-source: userset; mso-width-alt: 1792" width=49><COL style="WIDTH: 61pt; mso-width-source: userset; mso-width-alt: 2962" width=81><COL style="WIDTH: 55pt; mso-width-source: userset; mso-width-alt: 2669" width=73><COL style="WIDTH: 52pt; mso-width-source: userset; mso-width-alt: 2523" width=69><COL style="WIDTH: 57pt; mso-width-source: userset; mso-width-alt: 2779" width=76><COL style="WIDTH: 48pt" span=2 width=64><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 12pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=16 height=17></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 125pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=167>Brake Pad</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 84pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=112>Supplement</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 95pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=127>Caliper (L)</TD><TD class=xl22 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 74pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=98 colSpan=2>Rotor</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 37pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=49>Pistons</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 61pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=81>Dimensions</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 55pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=73>EBC Green</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 52pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=69>EBC Red</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 57pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=76>EBC Yellow</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 48pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=64>Ferodo</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 48pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=64>Pagip</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">Front</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl22 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">cm</TD><TD class=xl22 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">in</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" height=34>A</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; WIDTH: 125pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=167>34 11 1 162 535 E34 / E32
34 11 1 159 259 E32
</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; WIDTH: 84pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=112>JURID 187
JURID POLITEX
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; WIDTH: 95pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=127>34 11 1 160 367/368</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">302x22 V</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E3,3))/25.4" x:num="11.889763779527559">11.9</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>1</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">156x63x19.6</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP2689</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP3689C</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP4689R</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" height=34>B</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 125pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=167>34 11 1 162 535 E34 / E32
34 11 1 159 259 E32
</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 84pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=112>JURID 187
JURID POLITEX
</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 95pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=127>34 11 1 160 363/364</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">302x28 V</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E4,3))/25.4" x:num="11.889763779527559">11.9</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>1</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">156x63x19.6</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP2689</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP3689C</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP4689R</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>C</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">34 11 1 159 279 M5 3.6</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">JURID 595</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 95pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=127>34 11 2 226 873/874</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">315x28 V</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E5,3))/25.4" x:num="12.401574803149607">12.4</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>1</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">156x63x19.6</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP2689</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP3689C</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP4689R</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" height=34>D</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 125pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=167>34 11 1 160 708 E32
34 11 1 160 710 E32
</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 84pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=112>TEXTAR T476
TEXTAR POLITEX
</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 95pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=127>34 11 1 159 775/776</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">324x30 V</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E6,3))/25.4" x:num="12.755905511811024">12.8</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>4</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP2886</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP3886C</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP4886R</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>E</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">34 11 1 160 296 E31</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 84pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=112>JURID 514</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 95pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=127>34 11 1 160 325/326</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">324x30 V</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E7,3))/25.4" x:num="12.755905511811024">12.8</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>1</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">156x74x19</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP2870</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP3870C</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP4870R</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>F</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">34 11 1 163 922 E31</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 84pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=112>TEXTAR 4000</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 95pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=127>34 11 1 161 177/178</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">324x30 V</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E8,3))/25.4" x:num="12.755905511811024">12.8</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>4</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">120x71x17</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP21032</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP31032C</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP4102R</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>H</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">34 11 2 227 863 M5 3.8</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 84pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=112>TEXTAR 4056</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 95pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=127>34 11 2 227 115/116</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">345x32 V</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E9,3))/25.4" x:num="13.582677165354331">13.6</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>4</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">120x71x17</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP21032</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP31032C</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP41032R</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl28 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Rear</TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" height=34>X</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 125pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=167>34 21 1 158 266 E34-rest
34 21 1 158 270 E34-rest
</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 84pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=112>TEXTAR T477
TEXTAR POLITEX
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; WIDTH: 95pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=127>34 11 1 160 381/382</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">300x10</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E12,3))/25.4" x:num="11.811023622047244">11.8</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>1</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">123x44x16</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP2690</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP3690C</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP4690R</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 51pt" height=68><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 51pt; BACKGROUND-COLOR: transparent" height=68>Y</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 125pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=167>34 21 1 160 198 540i
34 21 1 160 199 540i
34 21 1 158 221 M5 3.6
34 21 1 158 562 M5 3.6
</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 84pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=112>JURID 508
JURID POLITEX
JURID 547
JURID POLITEX
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 95pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=127>34 11 1 160 399/400</TD><TD class=xl27 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 47pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=62>300x20 V</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E13,3))/25.4" x:num="11.811023622047244">11.8</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>1</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">123x44x16</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP2690</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP3690C</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP4790R</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Z</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">34 21 2 227 325 M5 3.8</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">TEXTAR 4057</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">34 21 2 227 873/874</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">328x20 V</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:fmla="=VALUE(LEFT(E14,3))/25.4" x:num="12.913385826771654">12.9</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>1</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">123x59x16.8</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP2871</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP3871C</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">DP4781R</TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR></TBODY></TABLE>
the US isn't obsessed with safety, only liability.
How true !
I think Australia is rushing headlong down the same path !
You can still do adventurous things in NZ and you are actually required to manage the risk YOURSELF !
Reg.
Where's everyone GONE !
Did I say something wrong, or should I have showered longer before before my last post !?!?!?!? :hihi:
Reg.
Hey guys,
I bought a set of the 3.8l E34 M5 4 pot calipers (for the 345mm rotors) from Wout, and i have had them blasted and powder coated, but I am having all sorts of trouble finding pads to fit them. Gone again posted is photo back in Post number 38 (http://www.m5board.com/vbulletin/showpost.php?p=967638&postcount=38)
The pad I'm after is the one on the left, but from what I can tell from reading this thread, all of the pads mentioned are the one on the right which are smaller, and presumably also able to fit the 4 pot calipers with the 324mm rotor.
Reg, the pads that you have listed for the 345mm rotor appear to be the wrong sort, they should be approx 99.3 x 74 x 18mm, I beleive that the 121 x 71 x 17mm pads are incorrectly listed in the Ferodo catalog, see the end of post #1 in this thread for more details.
So, can anyone give me a lead as to where I can find the correct size pads for these calipers/rotors please? I can always get them custom made, but it will take a few weeks, I would rather just find an off-the-shelf alternative.
Many thanks guys
John
