Hi Wout.
Here is an ETK page with E-32 4-spot calipers.
I don't know if there are other 4-spot calipers that were used in the E32, so I don't know if they are the ones that fit the E34; does anyone know ?
I'm pretty sure the 2-spot calipers in the same diagram are exactly the same units as are in my E34 540i LE, so my best guess is these calipers should fit an E34.
If any one knows any of these to be incorrect, let me know, I'll fix it and republish it.
Combo F had an incomplete caliper part number, I think the correct part number should have a "1" added after the "6", which I have done.
I have the table as an excel spreadsheet. We must not lose the acknowledgement to the source as the material is copyrighted by BMWE34.net.
<TABLE style="WIDTH: 430pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=573 border=0 x:str><COLGROUP><COL style="WIDTH: 37pt; mso-width-source: userset; mso-width-alt: 1792" width=49><COL style="WIDTH: 77pt; mso-width-source: userset; mso-width-alt: 3766" width=103><COL style="WIDTH: 63pt; mso-width-source: userset; mso-width-alt: 3072" width=84><COL style="WIDTH: 66pt; mso-width-source: userset; mso-width-alt: 3218" width=88><COL style="WIDTH: 72pt; mso-width-source: userset; mso-width-alt: 3510" width=96><COL style="WIDTH: 57pt; mso-width-source: userset; mso-width-alt: 2779" width=76><COL style="WIDTH: 58pt; mso-width-source: userset; mso-width-alt: 2816" width=77><TBODY><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 37pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" width=49 height=34>
Combo
</TD><TD class=xl25 id=r00 style="BORDER-RIGHT: black 0.5pt solid; BORDER-TOP: black 0.5pt solid; BORDER-LEFT: black 0.5pt solid; WIDTH: 77pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=103>
Bmw Model
</TD><TD class=xl25 style="BORDER-RIGHT: black 0.5pt solid; BORDER-TOP: black 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: black; WIDTH: 63pt; PADDING-TOP: 0cm; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=84>
Rotor size
</TD><TD class=xl25 style="BORDER-RIGHT: black 0.5pt solid; BORDER-TOP: black 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: black; WIDTH: 66pt; PADDING-TOP: 0cm; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=88>
Rotor part#
</TD><TD class=xl25 style="BORDER-RIGHT: black 0.5pt solid; BORDER-TOP: black 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: black; WIDTH: 72pt; PADDING-TOP: 0cm; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=96>
Caliper part# L/R
</TD><TD class=xl25 style="BORDER-RIGHT: black 0.5pt solid; BORDER-TOP: black 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: black; WIDTH: 57pt; PADDING-TOP: 0cm; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=76>
Clip part#
</TD><TD class=xl25 style="BORDER-RIGHT: black 0.5pt solid; BORDER-TOP: black 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: black; WIDTH: 58pt; PADDING-TOP: 0cm; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=77>
Carrier
</TD></TR><TR style="HEIGHT: 14.1pt; mso-height-source: userset" height=18><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 37pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 28.2pt; BACKGROUND-COLOR: transparent" width=49 height=36 rowSpan=2>
A
</TD><TD class=xl27 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; WIDTH: 77pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=103>
E32 730i (L6&V8)
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 63pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=84 rowSpan=2>
V 302 x 22
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 66pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=88 rowSpan=2>
34 11 1 160 936
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 72pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=96 rowSpan=2>
34 11 1 160 367/368
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 57pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=76 rowSpan=2>
34 11 1 157 687
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 58pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=77 rowSpan=2>
34 11 1 160 366
</TD></TR><TR style="HEIGHT: 14.1pt; mso-height-source: userset" height=18><TD class=xl27 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 77pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 14.1pt; BACKGROUND-COLOR: transparent" width=103 height=18>
E34 525i-535i-530i
</TD></TR><TR style="HEIGHT: 14.1pt; mso-height-source: userset" height=18><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 42.3pt; BACKGROUND-COLOR: transparent" height=54 rowSpan=3>
B
</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 77pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=103>
E32 735i/il L6
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 63pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=84 rowSpan=3>
V 302 x 28
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 66pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=88 rowSpan=3>
34 11 6 756 090
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 72pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=96 rowSpan=3>
34 11 1 160 363/364
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 57pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=76 rowSpan=3>
34 11 1 157 687
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 58pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=77 rowSpan=3>
34 11 1 160 365
</TD></TR><TR style="HEIGHT: 14.1pt; mso-height-source: userset" height=18><TD class=xl30 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 77pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 14.1pt; BACKGROUND-COLOR: transparent" width=103 height=18>
E32 740i/il-750i/il
E34 540i
</TD></TR><TR style="HEIGHT: 27.95pt; mso-height-source: userset" height=37><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 27.95pt; BACKGROUND-COLOR: transparent" height=37>
C
</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 77pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=103>
E34 M5 3.6
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 63pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=84>
V 315 x 28
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 66pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=88>
34 11 2 226 385
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 72pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=96>
34 11 2 226 873/874
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 57pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=76>
34 11 1 157 687
</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 58pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=77>
34 11 2 226 875
D
E32 740i/il-750i/il
V324 x 30
34 11 6 757 746
</TD><TD class=xl31 id=r10 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 72pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=96>
34 11 1 159 775/776
</TD><TD class=xl31 id=r00 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 57pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=76>
none
none
E
</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 77pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=103>
E31 840/850Csi
</TD><TD class=xl34 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 63pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=84>
V 324 x 30
</TD><TD class=xl34 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 66pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=88>
34 11 1 159 895
</TD><TD class=xl34 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 72pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=96>
34 11 1 160 325/326
</TD><TD class=xl34 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 57pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=76>
34 11 1 159 957
</TD><TD class=xl34 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 58pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=77>
34 11 1 160 327
</TD></TR><TR style="HEIGHT: 14.1pt; mso-height-source: userset" height=18><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 37pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 28.2pt; BACKGROUND-COLOR: transparent" width=49 height=36 rowSpan=2>
F
</TD><TD class=xl35 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 77pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=103 rowSpan=2>
E31 840/850
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 63pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=84 rowSpan=2>
V 324 x 30
</TD><TD class=xl36 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 66pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=88>
34 11 6 756 087
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 72pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=96 rowSpan=2>
34 11 1 161 177/178
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 57pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=76 rowSpan=2>
none
</TD><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 58pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=77 rowSpan=2>
none
</TD></TR><TR style="HEIGHT: 14.1pt; mso-height-source: userset" height=18><TD class=xl36 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 66pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 14.1pt; BACKGROUND-COLOR: transparent" width=88 height=18>
34 11 1 161 086
</TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl29 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" height=34>
G
E38 750il
V 334 x 32
34 11 6 757 756
does not fit
does not fit
does not fit
H
E34 M5 3.8 ('95)
V 345 x 32
34 11 2 227 735/736
34 11 2 227 115/116
34 11 2 227 506
</TD><TD class=xl38 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; WIDTH: 58pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=77>
Requires 17" wheels
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl43 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=2 height=17>
V is Ventilated Disc</TD><TD class=xl41 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 63pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=84></TD><TD class=xl41 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 66pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=88></TD><TD class=xl41 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 72pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=96></TD><TD class=xl41 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 57pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=76></TD><TD class=xl42 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 58pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=77></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=3 height=17>
Combos D, F & H are 4 -spot calipers</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=5 height=17>
Combo E 93-95 for the US 850Csi and up to 08/93 for other US Models</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=3 height=17>
Combo F 840-850 from 08/93 on</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=5 height=17>
Raw information for Combos A-C & E-H was originally obtained from</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=4 height=17>
http://www.bmwe34.net/e34main/upgrade/brakes.htm</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=5 height=17>
Combo D added during the development of this thread by E34_nut</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=5 height=17>
NEEDS CONFIRMATION FROM SOMEONE WHO HAS DONE IT</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=5 height=17>
Combo F had an incomplete part number for the caliper,</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=6 height=17>
I believe the correct number requires a "1" added after the "6". This has been done.</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR></TBODY></TABLE>
Reg.
