Hi
Looks good?! The 728 fronts are 316 x 28 and the M5 are 315 x 28. You need to check the callipers will fit the M5 front struts; can't see that they wouldn't, but ............. Ask your Pal if you can try them out, you really do need to 'butt them up' to ensure they do fit?
Are you sure they are Brembo? More likely they would be ATE, (the 345mm discs with '4 pot' callipers on the 6 speeders are ATE) not really relevant though all pretty much the same?
Cheers
Brian
Cheers
Brian
Geach said:Hi everybody, just a quick one. A friend of mine has recently crashed his e38 728i has started breaking it. The thing is it seems to have huge looking front brakes on it with 4 pot Brembo calipers. My question is; will this set up fit my M5? and is it worth doing? I know size isn't everything but i need to be looking at my brakes soon and this conversion crossed my mind any veiws appreciated.
Thanks Dan.:M5thumbs:
