Yep,but never could it work perfect on the master cylinder connection..Made me mad that it was after 4 tries still leaking there...Scrapped the idea and then went with a new original one...There was someone who had one custom made...but I cant find the thread.
That's right! I was thinking of having a custom braided line made up to replace both the hard line and flex line....but I'm not sure that I can find the proper diameter so that it fits in place of the stock line.Yep,but never could it work perfect on the master cylinder connection..Made me mad that it was after 4 tries still leaking there...Scrapped the idea and then went with a new original one...![]()
You'd have to figure out a way to weld the braided line to the hard line. I have a BNIB clutch line I was going to experiment with...Hmm, if I could get my hands on a used one, I know of a hydraulic shop I am almost sure they could make one up.
Could you flare the hard line?You'd have to figure out a way to weld the braided line to the hard line. I have a BNIB clutch line I was going to experiment with...
The problem is getting the braided line not to leak....You'd have to find some teeny tiny braided line for it to work that way.Could you flare the hard line?
15000 miles later. no leaks yet....The problem is getting the braided line not to leak....You'd have to find some teeny tiny braided line for it to work that way.
I've thought of doing the entire thing in braided line....but I'd have to find some in small enough diameter so that I could put the proper fittings onto it.
How was yours done?15000 miles later. no leaks yet....
CA used a local manufacturer, not sure who.How was yours done?
