So I just finished up an interior trim for a 04-07 BMW 645ci 650i that I wrapped in the new 3M 1080 CARBON FIBER vinyl. This type of finish is becoming more and more popular since people are getting away from the clear coated carbon fiber finishes. The trim is an OEM set of the silver trim option that you can get in a 04-07 6-series for around $1300.00 I believe. This is also a totally reversible process. If for some reason you want to restore the interior trim back to the OEM silver trim you can do so at anytime. Simply peel off the vinyl, and wipe the trim pieces down with some rubbing alcohol and all is back to the original finish with no blemishes at all. This vinyl is very durable, and moisture resistant. you can clean it by simply just wiping it off with a damp rag, it will not stain. If you get some armoral or vinyl dressing on it, simply wipe it off with some rubbing alcohol and it's all good.
OEM BMW 04-07 silver trim worth $1300.00, Custom wrapped in Carbon Fiber Vinyl (around 5hrs of labor) for $300.00. I would be interested in working out some sort of trade for your trim if you don't want it, I would like to wrap that and sell it to another lucky owner n so on...
Mark Wu
206-707-6491
Renton Skyway
DIY instal link: 6 series interior trim removal - bimmerfest - BMW Forums
Check out some of my work:
Carbon Fiber Wraps Interior Exterior Fabric 3M DI-NOC | Facebook
Mark Wu
206-707-6491
Renton Skyway
